miguelgandia
Building Problem
When I try to build the package. It says Build required. What does this mean?
Re: Building Problem
I'm not sure why you encountered this behavior. When the "Build required" message appears, it means that the output builds are not "up to date" and a "Rebuild" is required.
Can you use the [Rebuild] option and see if the behavior still persist? If it does, please send us the .AIP(project file) to support at advancedinstaller dot com so we can investigate it and a give us a test case scenario.
Also, you might get this behavior if you manually edit the .AIP(project file) with a text editor and downgrade the "Project type" (e.g. from "Enterprise" to "Professional").
Let us know if that helped.
miguelgandia
That was the problem. I downgrade manually the file. I started again and is working for now.
Thanks!
You're welcome.
