McKool
Organization Page - Advertice Radio buttons
AI: 10.7.1
OS: Windows 8.1 - 64 BIts
The radio buttons on the "Avertise Settings" of the Organization page are selected at the same time (see picture):
Both radio buttons selected
Advertise Issue.jpg (80.13 KiB) Viewed 3912 times
After this issue happened the radio buttons will be shown selected for all any other features within a project. Restarting AI help clearing the second radio button.
The change of the advertise option seems not to be registered as a "project modification". If you change from Allow advertise to disable or vice-versa, and then you try to close the project, no message asking for save the project is shown.
Attached is the test project used for the picture above.
RB-Issue.aip
AI Project
(11.99 KiB) Downloaded 364 times
Re: Organization Page - Advertice Radio buttons
Indeed, this seems to be an Advanced Installer issue. A fix will be available in the next version of Advanced Installer (10.8) which should be available in a few days, thank you for bringing it to our attention.
Meanwhile, you can go in the Table Editor page, "Feature" table and modify the "Attributes" column of the feature to match your preferences, as described in the MsiSetFeatureAttributes function article.
This was fixed in version 10.8 of Advanced Installer released on December 10, 2013.
McKool
Thank you Daniel!
Keneth.
You're always welcome.
