Codename K
Unchecking a checkbox during installation?
In my Finish dialog I show a checkbox. Based on a condition it need to check or uncheck automatically. How to do that?
K
Re: Unchecking a checkbox during installation?
In order to achieve this you can create two "Set installer property" custom actions in the "Finish Dialogs Stage" section to set or delete the property related to your checkbox. For example, if the checkbox property is [MY_CHECKBOX] you can use two control events like below:
  • Property: MY_CHECKBOX
    Value: 1
    Condition: <true>
    Value: {}
    (this is how a property can by set to empty, deleted)
    Condition: <false>
Let us know if this helped.
Codename K
I am checking for an application running using the AI_PROCESS_STATE method. If it is Running then the check box needs to be unchecked. This did not work. The conditions are AI_PROCESS_STATE = "Running" and AI_PROCESS_STATE = "Stopped".
K
This may happen if your "Detect Process" custom action is added in the "Install Execution Stage" section. In this case the value of the [AI_PROCESS_STATE] property that is set to in that section is not passed to the "Finish Dialogs Stage" section because this is the Windows Installer default behavior.
So, to overcome this problem you can drag the "Detect Process" custom action to the "Finish Dialogs Stage" section above the "Set installer property" custom actions.
Codename K
Splendid, worked perfectly. Thanks as always.
:D :D :D
K
You're welcome. Glad to help.
