Korush
updates without elevation does not work
according to http://www.advancedinstaller.com/user-g ... dates.html
I tried to config auto updater as a service. but when I want to start "updater.exe" service I get the following error:
"The updater service on Local Computer started and then stopped. Some services stop automatically if they are not in use by other services or programs."
Would you please help me? I can not figure out whats wrong exactly, I attached the project.
sample.zip
(729.05 KiB) Downloaded 183 times
Re: updates without elevation does not work
Please keep in mind there is no need to manually start the installed updater service. All you have to do is to configure the updater as it is exposed in our How to handle updates without elevation? article, then install (using an admin account) the first version of your project and then you can run the installed updater from any standard account in order to silently install updates.
Please note that in your updates configuration file project you should enable the install updates without elevation option in order to install the updates without elevation.
Also, you can take a look on our Auto updates for non Admin users forum thread where you can find a sample which implements this scenario, to install updates without elevation.
