sonu
Finding the Domain name of the Current USER.
Hi team,
Can you help me out on finding the domain name of the Current who logged in. We are creating the user under same domain, Is there any predefined property for find Domain in advanced installer '..."[%USERDOMAIN]....is it use full ?
With Regards,
pradeep
Re: Finding the Domain name of the Current USER.
Hello pradeep,
You can use the Environment.UserDomainName Property which gets the network domain name associated with the current user.
Edit: Also, you can take advantage of the USERDOMAIN environment variable.
First, you should go in the Install Parameters page and create a public property (e.g. USER_DOMAIN_PROP).
Then, you can go in the Custom Actions page and add the Set installer property predefined custom action with sequence. You can edit its properties like that:
  • Property: USER_DOMAIN_PROP
    Formatted: [%USERDOMAIN]
