Arthur
Prerequisite registry key not working?
I'm trying to install Gimp as a prerequisite. I'm doing a registry search for an uninstall entry which will tell me if it's already installed. It doesn't work. When I search using regedit I can see the entry, but when I try to find it through Advanced Installer, it sees a different entry in the same place. See the attachment.
Arthur
Re: Prerequisite registry key not working?
Hi Arthur,
By default, only the 32-bit registry entries are displayed (the registry entries that are located under Wow6432Node). Can you try to select the "Use 64-bit locations when evaluating conditions on a 64-bit machine" option and see if the needed registry entries are displayed?
Arthur
That worked, thanks.
You're welcome.
