kjullion
Auto Updater Questions:
I have the auto updater working fairly well, but I would like to know what the options are to provide a bare-minimum-user interaction with the updater interface? Ideally I would like a message that says "Install is available" and if user agrees to it, then it should be auto downloaded and auto installed without the user having to click Next> through the various screens.
In that same light, can the check-box on the Updater exe UI that is called "Automatically install updates after finishing download" be disabled or better yet left "on" and hidden?
Secondly, why does the MD5 integrity checker take so long? My download time is <1 minute but the integrity checker seems to be about 3-5 minutes long. It makes the updater looks like it has stopped responding. Eventually when the MD5 check is completed the installer does start up.
Thanks.
Re: Auto Updater Questions:
Hello Sony,
Can you please give us more details about your currently configuration from the Update Behavior? What user interface are you getting now when you running the Updater?
I'm afraid there isn't any setting which you can do to disable or hide the "Automatically install updates after finishing download" option.
I'm not sure why you encountered this behavior. Can you please tell us the size of your downloaded file?
kjullion
Hi Dan,
On the Update Behavior page I have this options selected:
  • "Silently check for updates and automatically install" is On
    "Do not use check frequency" is On
    "Install only Critical updates" is Off
    Silent mode update check freq. is set to 1 days
    "User cannot disable automatic updates check" is On
    "Install Support service" is On.
The user interface we are getting is the following
  • Choose Updates to Install (with check-box, Next and Cancel buttons)
    Downloading Updates (with progress bar, pause, "automatically install...finishing downloads", Next and Cancel buttons)
    Installing Updates
What we really want re the user experience is for the to to be able to say "Yes, I want the found update to be installed" and then make it virtually click-free and options-free. The more options and the more clicks the more the customer is going to complain.
Re the MD5 slowness, that appears to have been a one-off problem. I don't see it any more. Feel like it had to do with the Virtual machine doing an automatic update from MS.
Thanks.
Indeed, our default implementation is the one you currently use.
However, we are trying to make Advanced Installer as useful and complete as possible, so we would appreciate your suggestions. Almost every feature in Advanced Installer has been shaped in accordance with the needs of the users.
So, could you please provide more details about this capability? What would be the things that you would require? How would you like to be the User Interface? Would you like to be a progress dialog during the updates installation?
kjullion
Hi Dan,
Yes, for us (and particularly our users) "less is more". We don't want them to have much flexibility in the when or the how that an update is applied. We do offer a pull mechanism, such as "Help > Check for Auto Updates...", but our main focus would always be on the on-applicatoin-start-up auto check.
When an update is found to be available from our download site we prompt them with one of three buttons:
Download and Install now
Download and Install later
Remind me later
The "Remind me later" option is only offered for a small period of time, such as 3 allowed delay days per update, so if they use our app 4 days in a row then the "remind me later" option will disappear by the 4th day.
As far as the UI goes, when the clicks one of the 2 (above mentioned) "Download" buttons we flip the UI to a progress bar showing the download percentage. If they are doing the "install later" then we just launch our app and on closing/exiting our app we prompt them with: "An auto update has been downloaded, do you want to install it now? Yes/No". Again they can only choose "No" for a limited number of times.
If they are doing the "Install now" option then we install and auto-start the system with their newest version.
I hope that helps with some ideas of what we would like to see made available.
Thanks.
kjullion
Hi Dan,
Perhaps I should have given more specific examples about the AI Auto Updater features we would like to see altered.
On the "Choose Updates to Install" screen we would like to see (an option) to remove the check-box that is part of the list-box of available updates ...if the user un-checks our one available update what would be their expectation when they click the "Next>" button? I think that's not as intuitive as it should be.
On the "Downloading Updates" screen we would like to see (an option) to remove the "Automatically install updates after finishing downloads". It's not totally clear what would be the user's experience if they turn off the check-box and the download finished...what event would trigger the actual install to occur?
Finally, and less importantly, on the "Downloading Updates" screen we would like (an option) to remove the "Pause" button.
Kevin
Hello Kevin,
Thank you for your suggestions and the details you had provided. Some of them will be implemented in a future version of Advanced Installer.
Please note that if there is only one update available and the user un-check, then the Next button will be disabled, the user cannot proceed further.
If you uncheck the Automatically install updates after finishing downloads option, the updates will take place when the user hit the Next button. If this option is selected then the update will be automatically installed after it has been downloaded.
kjullion
Hi Dan,
Is it possible for us to get UAC-less updates to work if we do not use your proprietary Updater.exe?
To put it another way: we have our own equivalent of what your call your "Updater.exe" and our customer's have sort of driven the user experience surrounding our "updater" process. The beauty of that is that we are able to fully customize our "updater" user interface for each individual clients special requirements. Definitely our current installer has to be upgraded in order to get the UAC-less updating, so this our primary intent on going forward with AI.
Thanks.
Unfortunately, the support service which handles the updates without elevation is installed and configured for our Auto Updater.
kjullion
Hi Dan,
We are ready to purchase, but what is holding us back is the Updater UI and it's configuration properties, so I'm looking for some more help on what I can do to move forward.
Has there been any discussions at AI about if and when there might be some design changes to the Updater.exe? In this thread you asked for some of my feedback on what we would like to see changed. I would assume that others have asked for changes too. Is there anything new with regard to the UI of the Updater.exe in the v10.9? I have not looked at 10.9 yet.
For us, as it is now we can't use the Updater.exe because we need near-zero-interaction by the end user with regard to accepting an available update. Or, maybe you can suggest what switches/parameters/flags I can use to achieve a near-zero-interaction update and installation? I have read the descriptions on each of the available options that are in the Help but it's not totally clear if it is possible to do what we need and our clients require.
What would be ideal for us is an updater screen that is like the one that AI itself uses (see attached), but with the "Disable the automatic update check" and "Configure Options" and "Cancel" options hidden/removed. That is why I put a small redline through those options in the attached screen shot.
If the user selects the "Download and Install Now" option they should not have to do anything else to make the installation take place, sort of an update-auto-pilot if that makes sense.
If the user selects the "Remind me tomorrow" option they will get the exact same choices and end-user experience as they do when prompted today.
The "Remind me tomorrow" should ideally also be configurable, so that for those of our clients that request it may need it to be that the user never be allowed to delay the auto update, then there only option is to "Download and Install Now". This amounts to a forced auto-update without any delay/procrastination. The reason we need this is that our applications updates can be time/money/interest rate sensitive, and the client does not want the end user to be able to use old values stored in the prior release once the new release has been approved and published.
Thanks.
AI Found Updates1.png (20.15 KiB) Viewed 15482 times
kjullion
Hi Dan,
I went through the process on a VPC of updating from AI 10.6 to 10.9 to see how the Updater.exe screens work in more detail and I saw something that you might want to consider looking into.
*see screen shot and make sure you scroll to the bottom of the image*
I chose to turn "off" the setting to "Automatically install updates after finishing downloads" and when the download was finished the checkbox is still enabled so clicking it "on" or "off" after the download has finished does nothing. It seem like that checkbox should probably be treated like the "Pause" button in that once the download is finished the "Pause" button is no longer applicable. I think the checkbox should be the same.
Just a thought!
Kevin
AI Download Finished.png (18.5 KiB) Viewed 15478 times
Hello Kevin,
We already have this on our TODO list and this feature will be available in a future version of Advanced Installer.
Thank you for the provided details.
kjullion
It's been almost two months so I thought I would try to find out if the Updater user interface has been re-worked in AI v11.0? By re-worked I mean has it undergone any changes that might resemble what we are looking for and what I documented in this thread?
And, if not, do you have any set time-frame on when these future changes might be made available?
Kevin
Hi Kevin,
Most of the features which you have asked for will be available in the next version (11.1) of Advanced Installer. e.g. You will have the possibility to prevent the user to configure the options from the Updater Wizard and others.
We are trying to make Advanced Installer as useful and complete as possible, so we appreciated your suggestions. Thank you for that!
These improvements have been added in version 11.1 of Advanced Installer released on April 28th, 2014.
