sonu
[TARGETDIR] is already registered error
Hi Support,
Am getting "The [TARGETDIR] is already registered in the table while opening the project file. Its built in advanced installer 10.3. Its urgent please fix this issue. Attachd the proeject file
Copy (3) of Agile_Branch_Back_Counter.aip
(740.42 KiB) Downloaded 335 times
Re: [TARGETDIR] is already registered error
I'm afraid your .AIP is not as easy to fix as it looks like. This is why we are very interested to find out how you got this? Did you manually edited the .AIP(project file) in a text editor? Can you give us a detailed test case so we can investigate this?
sonu
Hi Dan,
This is one of our installer project file getting this error when trying to open the project. Please let me know what information you need.
Regards
Sony
Hello Sony,
I would like to know if you had added a folder; have you renamed; have you used a drag-and-drop operation; have you deleted, etc. Also, the .AIP (project file) has been only edited in Advanced Installer or have you used a text editor or SVN?
Can you give us a detailed test case which can replicate this behavior because we are very interest to find out which operations can lead to an such an unexpected behavior.
