sjeslis
Product Name Reverting After Command Line Build
I have an established AIP that I'm trying to change the Product Name (from Product Details panel). I change the string from "Master Server" to "Cicero Server".
I rebuild from the UI, close the project and re-open it and the Product Name is still what I changed it to.
I run our MSBuild script on it which invokes the following AI command line:
AdvancedInstaller.com /rebuild "full path to AIP file" -buildslist Release
and the Product Name gets reverted to "Master Server".
I'm on 10.8 but this AIP has been converted through many AI upgrades.
Deleting all the "cache" folders did not help either.
Scott Jeslis
Senior Software Engineer
Cicero, Inc.
Re: Product Name Reverting After Command Line Build
In order to have a better view about this can you please send us the .AIP (project file) to support at advancedinstaller dot com so we can investigate it? Also, can you please give us a detailed test case? Did you changed the Product Name in UI of Advanced Installer and after Executing a file of commands the Product Name in the .AIP was reversed?
Happy New Year,
sjeslis
Yes I changed the Product Name through the UI. Then we have an MSBuild script that runs other non-Advanced Installer commands and then runs the rebuild command I provided above. When that happens it seems like the product name is changed.
Scott Jeslis
Cicero, Inc.
sjeslis
Never-mind Dan. My issue... I just found a SetProperty /ProductName being done in our script. :oops:
Happy New Year!
Scott J.
Scott Jeslis
Cicero, Inc.
Happy new year to you too, Scott
Glad you fixed this. If you have other questions, please let us know.
