Eusch
Howto distinguis between component in organisational view
If a registry key+value name test1\\ip and test2\\ip I get two items in the organisational view. However I cannot determine which component in the organisational view belongs to which registry key.
dorel
Hi Eusch,
Organization View displays as component name the Component column from component's row. You can do the following trick to determine which key belongs to which component: modify the name of the registry value and then go to Organization view and find the component
that has a resource with the new name- that is the component of the registry value. Modify the component in Organization view as you want ant then rename the registry value to its original name.
Dorel Pislan
Advanced Installer Team
