So I test it again. I uninstall 1.0.1.
and I install 1.0.0 again. and I find when setup finish, I can search and find the file:C:\WINDOWS\Microsoft.NET\assembly\GAC_32\System.Data.SQLite\v4.0_1.0.87.0__db937bc2d44ff139\System.Data.SQLite.dll
this time I'm not open the application.......
and I'm update the application to 1.0.1. for the test, I'm move the update package file to :C:\update.exe
and I'm click the update.exe update application to 1.0.1 and search System.Data.SQLite.dll from GAC, but I'm not found........
then I'm rename update.exe to update2.exe(for let the dialog display)
I open the application. my application display some error, and Windows display System.Data.SQLite.dll come back......
application still loading....this time it not let me select package file, and then the computer auto restart.......
when application restart....Sqlite.dll already back to the GAC.
I check my application Error log, there is details:
2014-01-08 00:47:21,281 [1] ERROR - Object reference not set to an instance of an object.
System.NullReferenceException: Object reference not set to an instance of an object.
at Player.App.SignalExternalCommandLineArgs(IList`1 args)
at Microsoft.Shell.SingleInstance`1.LYEQAZRjG(IList`1 args)
at Microsoft.Shell.SingleInstance`1.kAjefvMsa(Object )
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
2014-01-08 00:47:21,875 [1] ERROR - Value cannot be null.
Parameter name: window
System.ArgumentNullException: Value cannot be null.
at System.Windows.Interop.WindowInteropHelper..ctor(Window window)
at System.Windows.MessageBox.Show(Window owner, String messageBoxText, String caption, MessageBoxButton button, MessageBoxImage icon)
at VodPlayer.App.J7CygvLMgPXmk3VjOJ(Object , Object , Object , MessageBoxButton , MessageBoxImage )
at Player.App.YYyG69NC4(Object )
at Player.Res.Exceptions.ExceptionPro.aPM6eIBu8(Action`1 action, Object , Object )
at Player.Res.Exceptions.ExceptionPro.ExpLog(Exception ex, Action`1 action, Boolean IsInfo, String designationMessage)
at Player.App.Wmf3axwu8(Object , Object )
at System.Windows.Threading.Dispatcher.CatchException(Exception e)
at System.Windows.Threading.Dispatcher.CatchExceptionStatic(Object source, Exception e)
at System.Windows.Threading.ExceptionWrapper.CatchException(Object source, Exception e, Delegate catchHandler)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean ignoreSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
2014-01-08 00:47:21,968 [1] ERROR - Value cannot be null.
at Player.App.Main()
2014-01-08 00:48:31,515 [1] ERROR - Could not load file or assembly 'System.Data.SQLite, Version=1.0.87.0, Culture=neutral, PublicKeyToken=db937bc2d44ff139' or one of its dependencies. System Can't file Specify file。
System.IO.FileNotFoundException: Could not load file or assembly 'System.Data.SQLite, Version=1.0.87.0, Culture=neutral, PublicKeyToken=db937bc2d44ff139' or one of its dependencies. System Can't file Specify file。
File name: 'System.Data.SQLite, Version=1.0.87.0, Culture=neutral, PublicKeyToken=db937bc2d44ff139'
at Player.ViewModel.Loader.CheckPathAndSql()
at Player.LoginWindow.iOf9L0OqeYjxSdQfunF()
at Player.LoginWindow.tkavIBdpd()
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
and I check the windows Log, there is details:
- Windows Log.png (74.8 KiB) Viewed 9782 times
