dfbdp
MSI package problem
I have just bought AI pro, and are working on some SILENT simple packages where the overall process in AI is the same. I need to install a existing program, and then change/add some things, which is the problem.
The progress i made sofar (Example is with IBM Iseries Access):
1) Insert default programfiles in a temp folder like "Windows volume - Temporary". Temp would be the best, since the files are only to be installed and must be deleted after installation.
2) Set ”Limit to basic userinterface” in install parameters.
3) Set ”Single MSI (Resources inside” in Media tab, since the output MUST be in 1 MSI due to management and rollout.
4) Call the setup.exe from ”Custom Actions” where i choose ”Launce installed file” and choose the ”setup.exe” in the temp folder i just added and set the executiontime to ”When the system is being modified”. The custom action is now below the Add Resources in the install execution stage.
I have done this with IBM Iseries Access software and i can save, build and run the MSI file just fine.
The single MSI file installes the ISeries Access so thats fine, but now to the problem.
I encounter are continueiung problem when i want to CHANGE or ADD a action.
I now need to run a homemade BAT file, which copies some links to the userdesktop etc.
If i run the bat manually, it works.
But i cant figure out how to EMBED this batfile into the existing project and get it to build and run.
I keep getting an error, which says ”The package has an error
I have tried the following forumthread descriptions without any luck:
http://www.advancedinstaller.com/user-g ... -file.html
http://www.advancedinstaller.com/user-g ... ation.html
I am sure, it just a matter of getting the order or process done correctly but i am pretty stuck now. 
So i need help with this, since i need to make several packages with the same setup.
Program install and then change thorugh batfile.
I will gladly upload the ”IBM Iseries access” DVD and my batfile to a sharesite, if anyone could make me an example of what the project should look like???
Please help, thx.
Best regards
Brian Petersen
Re: MSI package problem
Hi Brian,
You can see my response on the Run Batchfile after installation problem thread.
