bchetana
Error calling Wix Custom action
Hi
I am using 10.8 AI. I have a Wix Custom action dll which has set of .net custom actions. every thing was working fine.
Suddenly when ever I rename the old custom action function or add new, I am getting the following error.
ScreenHunter_01 Jan. 06 17.31.gif (37.1 KiB) Viewed 7363 times
Is this issue specific to 10.8 version of AI. When I was using 9.8 I did not face this problem
Please Confm ASAP
bchetana
Re: Error calling Wix Custom action
This is the error that log for the issue:
SI (s) (A8:78) [11:19:26:817]: Doing action: SWTangoServiceCustomAction.CA.dll_6
Action start 11:19:26: SWTangoServiceCustomAction.CA.dll_6.
MSI (s) (A8:F8) [11:19:26:895]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI3590.tmp, Entrypoint: StopInstallation
MSI (s) (A8:78) [11:19:26:942]: Note: 1: 1723 2: SWTangoServiceCustomAction.CA.dll_6 3: StopInstallation 4: C:\WINDOWS\Installer\MSI3590.tmp
MSI (c) (EC:D0) [11:19:27:130]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
Error 1723. There is a problem with this Windows Installer package. A DLL required for this install to complete could not be run. Contact your support personnel or package vendor. Action SWTangoServiceCustomAction.CA.dll_6, entry: StopInstallation, library: C:\WINDOWS\Installer\MSI3590.tmp
MSI (s) (A8:78) [11:23:04:689]: Product: Steelwedge Cloud Connect -- Error 1723. There is a problem with this Windows Installer package. A DLL required for this install to complete could not be run. Contact your support personnel or package vendor. Action SWTangoServiceCustomAction.CA.dll_6, entry: StopInstallation, library: C:\WINDOWS\Installer\MSI3590.tmp
Action ended 11:23:04: SWTangoServiceCustomAction.CA.dll_6. Return value 3.
Action ended 11:23:04: INSTALL. Return value 3.
Its very critical... Can any one give the root cause for the issue ASAP
Can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
You can also try to debug the related custom action.
bchetana
Hi
I Have send the details.
