kjullion
Updater UI missing data after minimize then restore
When testing the Updater.exe I found that if I minimize it during the "Installing..." phase the Updater user interface goes bad.
When the Updater UI first loaded it had everything correctly populated. During the "Downloading..." phase I did nothing but sit there and watch it; then during the "Installing..." phase I decided to minimize the Updater UI, and when I restored the UI it had a bunch of missing data (see attached screen shot).
I actually had to do an "End Task" to get it to go away as well.
My test environment is a 32-bit Win7 Virtual PC.
Updater blanks out.png (13.1 KiB) Viewed 2037 times
Re: Updater UI missing data after minimize then restore
I'm not sure why you encountered this behavior. I've tested your scenario but I cannot reproduce it.
Can you please try to test this on another clean machine and see if the behavior still persist? If it does, can you please give us a test case so we can investigate this?
