lidds
Shortcut Icon dissappears...
For some reason my application icons sometimes dissappear from the start menu and shortcuts. I searched your forum and found the following link http://www.advancedinstaller.com/forums ... disappears which provides a solution to the issue and that is the tick the "Do not delete extracted MSI and CAB files". However I previously was building my application using "EXE setup with resources next to it" which does not allow this option. Therefore I have changed my default build to build a "Single EXE setup (resources inside)" and ticked the "Do not delete extracted MSI and CAB files" in the hope that this solves the problem of icons dissappearing. However I now have another problem that no MSI file is built and therefore am unsure how I would create patches for my new versions as to create a patch you need past and present MSI files. Therefore is the solution for me to add another build type to my installer and set this to "Single MSI (resources inside)" and run both of my builds, therefore creating a single exe file for the initial version of my software and a MSI file if I wish to create a patch?
I just need some guidance on how you would recommend to approach the above senario?
I have attached 2 screen shots showing the setting of both build types.
Simon
SingleBuild
SingleBuild
MSIBuild
MSIBuild
Re: Shortcut Icon dissappears...
For creating a patch you can extract the installation files from the EXE by using the /extract command. After you extract both versions of the package into different folders, you can use the extracted MSI files to create the patch. In order to create a Patch you can take a look on our Patch authoring tutorial. Please keep in mind that when you authoring a patch package you have a number of restrictions.
You can also take a look on the How to create patch of .exe ? forum thread which debates a similar issue.
Please let us know if you have other questions.
lidds
Dan,
Thanks for your help this resolves my concern
Cheers
Simon
You're welcome Simon,
Errol
Good morning
I have just installed Advanced Installer 11.1 Freeware or a 64-bit Windows 7 machine, with a view to using it as my primary installer application, and eventually purchasing the Professional package. I created a simple install package primarily using default settings, and ran this from Advanced Installer. Everything worked fine, and shortcut icons appeared in both the Start Menu and on the desktop (even though I only specified [DesktopFolder]. I had to tweak things a bit so I guess I installed and uninstalled the application 3 or 4 times.
I then ran the .msi file directly. Again the program installed but now no icons are displayed, not on the Desktop or in the Start menu, even in All Programs. The program also does not show up in the list in Control Panel \ Programs and Features. I then tried running the install direct from Advanced Installer and the icons do not appear anywhere. I have tried rebooting the computer, but no change. In other words, the only way to run this program is to manually copy a shortcut from the application directory, which is far from satisfactory.
It appears that Advanced Installer has suffered from this or similar problems for a number of years, and it looks like it has not yet been fixed. There has been some suggestion that this is a Windows problem (and I can believe this) but Advanced Installer needs to solve the problem rather than blaming it on the OS. This is hugely disappointing and something of a black mark against your application.
I look forward to suggestions how to fix this.
Best regards
Errol
Hello Errol and welcome to Advanced Installer forums,
In order to have a better view about this, can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them? If it contains confidential information you can send us a small test project which reproduce this behavior.
Errol
Hi Dan
Thanks for your reply and sorry for the delayed response. I cured the problem by unchecking the Disable Modify, Disable Repair, Disable Remove and Do not show in list in Product Details \ Add or Remove Programs (Control Panel). The program is now listed in the Control Panel Program List, and the program icon is now shown both on the Desktop and in the Start Menu. I do not quite understand why checking these options prevented the icons in the Desktop and the Start Menu.
Anyway it is now working fine, thanks.
Errol
Hi Errol,
This was happening because you have disabled the Register product with Windows Installer option from the Product Information page.
