lionelsiu
Setting Permissions for Registry failed
I am trying to set permissions for a registry key. Please see the attachment.
However, after installations, the permissions cannot be created.
The Users group still can only obtain Read permission. And no permissions for Everyone.
Could anyone give help? Thank you.
#I am running on Windows 7 64-bit.
mihai.petcu
Re: Setting Permissions for Registry failed
Hi there,
Try setting the same permissions for the parent keys (excluding the root hives and Software). Windows Installer sometimes fails to set permissions on sub-keys if their parent keys don't support them.
lionelsiu
Thank you for your reply. However, the problem still persists, is there any other solution? Thanks.
mihai.petcu
There are known problems with the way Windows Installer sets permissions. However, you can manage the permissions the way you need by using the Xcacls.exe tool as a custom action.
