CraigA
Can't pass [APPDIR] to .NET Installer Class Action
I'm using a .NET Installer Class Action in order add some custom windows firewall rules. It works fine until I try to pass in the application install folder using the [APPDIR] property. When I provide [APPDIR] in the Installer Class Parameters dialog, I get a System.IO.FileNotFoundException. I can can pass in any other literal string like : "c:\foo\bar" and the installer proceeds without error.
Here is the error dialog:
Here is the custom action configuration:
What is causing this error? I believe this is the documented way to send install properties to the .NET custom install class.
Re: Can't pass [APPDIR] to .NET Installer Class Action
I think the problem is that the trailing "\" character from the value of APPDIR ("c:\foo\bar\") causes the next quote character to be escaped. To prevent this, include a space character after [APPDIR] in the Installer Class Parameters. So, when define your Installer Class Parameter – AppDir just add an space character after its value: [APPDIR] .
Another issue, although not related to the problem you are encountering, is the place where you have scheduled your Custom Action. You should add it under "Install" as "Deferred with no impersonation", because it performs system changes and it will fail if executed as Immediate.
By the way, have you noticed our predefined support for creating Firewall exceptions from the Windows Firewall page? Here, you can add applications or ports that you want to authorize / register in Windows Firewall.
