doctorp
Licensing - CryptoLicensing
Hi there
I found the tutorial here: http://www.advancedinstaller.com/user-g ... nsing.html quite useful.
However I think this might still be beyond me.
I would like to integrate my cryptolicensing licensing service with the installer so that it verifies the user's code against the server and allows them to install if a valid code is entered.
I'd also like them to be able to install a trial version which will install a public constant that I specify into the registry.
I can write the licensing code in VSTO with no problems - I guess I'm looking for some guidance here to integrate with advanced installer.
Cheers
Doc
Re: Licensing - CryptoLicensing
Hello Doc,
You can also take a look on our "Integrate licensing and trial support in my application" how to's which could be useful for you.
In order to achieve this you can use our "Package Serial Validation" support.
I'm afraid I don't fully understand your scenario. Can you please give us more details about this (maybe exemplify)? In order to add trial functionality to your application you can use our "Advanced Licensing" feature.
