litu
conditional text update file
We want to add a dialog on our installation that asks the user to choose one of two options (with a combo box). That's easy. The non-easy part (for me) is to change the value of an xml file depending of the user's choice. If the user has chosen "http", then change the xml file replacing XXX for "false" and if the user has chosen "https" on the combo box, then change the xml file replacing XXX for "true".
How can I do that?
Thanks in advance.
Arnau.
Re: conditional text update file
Hello Arnau,
In order to achieve this you can add a combo box control (e.g. COMBO_PROP) on your dialog with two items like this:
  • Text: http
    Value: false
    Text: https
    Value: true
Then, you can import your XML file in "Files and Folders" page and edit its XXX element/attribute value to use the "COMBO_PROP" property.
litu
If I do that in the combo box a strange thing happens...
After selecting "http" or "https", the "true" or "false" value is shown on the combo box. The user doesn't need to see that, it's confusing.
Arnau.
litu
I don't know if I've explained myself enough or not. So, two images woth two thousand words... ;)
First image of the combo, before selecting anything
Second image of the combo, once one value is selected.
Hello Arnau,
If you want to avoid this behavior, then you can use an additional property (MY_PROP) which will be set depending on COMBO_PROP property value. Here are the steps to proceed:
- in "Dialogs" page add a combo box control with the following items:
  • Text: http
    Value: http
    Text: https
    Value: https
- select the above combo box control and add the following events on its published events tab:
  • Event: Set installer property value
    Property: MY_PROP
    Argument: true
    Condition: COMBO_PROP = "https"
    Property: MY_PROP
    Argument: false
    Condition: COMBO_PROP = "http"
- use MY_PROP property to update your XML file
- build and run your project
litu
Yes! It worked!
Thanks a lot.
Arnau.
Note for Caphyon CEO: the support guys deserve a raise!
You're always welcome Arnau. Thank you for your positive words.
