Invalid license data. Reinstall is required.
Having trouble running Advanced Installer? Got a bug to report? Post it all here.
Post Reply
MichelZ
Post by MichelZ » Tue Jan 28, 2014 9:09 am
Hello
We have a similar problem as in:
http://www.advancedinstaller.com/forums ... 150#p58439
The error when we try to import a WiX project is:
Microsoft Visual Studio 2010 Shell: Invalid license data. Reinstall is required.
We do not have a full Visual Studio 2010 installed, only the Shell (Standalone mode)
It was most probably installed by MSSQL Management Studio 2012
We do have Full Visual Studio 2012 Premium and Visual Studio 2013 Premium installed.
Anything we can do?
We are trying to evaluate Advanced Installer's capabilities, and the first feature we use does not work.. :(
Michel
Re: Invalid license data. Reinstall is required.
Post by Dan » Tue Jan 28, 2014 3:01 pm
Hello Michel and welcome to our forums,
Can you please try to enable the I don't have a WIX Visual Studio project file. I'll pick the source files manually option during Wix Import Wizard and see if the behavior still persist?
MichelZ
Post by MichelZ » Tue Jan 28, 2014 3:56 pm
With this I get:
CustomActions.wxs: error CNDL0150: Undefined preprocessor variable '$(var.Platform)'
MichelZ
Post by MichelZ » Tue Jan 28, 2014 4:00 pm
OK, I figured out that the Variables need to be named without $() and without var.
So:
Platform=x86
After doing that to all errors, I now get:
A row with this key [APPDIR\Webservice\bin] was already registered in the table.
on action:
Resolving external tables references.
I guess I'm better off creating a new installer from scratch? :)
Post by Dan » Wed Jan 29, 2014 9:43 am
Hi Michel,
So:
Platform=x86
Indeed, you have to define the related variables from the script in the Wizard Preprocesor page.
You can create an Advanced Installer from scratch. However, we would greatly appreciate if you could send us the WIX project to support at advancedinstaller dot com so we can investigate this.
MichelZ
Post by MichelZ » Wed Jan 29, 2014 10:17 am
Thanks Dan, I've sent the WiX project through.
Post Reply
