default
Bug! for Windows 2012R2 VersionNT64=602
hi
I have a strange problem.
There are 2 project (old series with the imported version 9.6) and new, created in 10.9
when run on Windows 2012R2 property VersionNT64 for old project VersionNT64 = 602, and for the new VersionNT64 = 603
how to fix this problem?
Re: Bug! for Windows 2012R2 VersionNT64=602
Indeed, this is an Advanced Installer issue which can be encountered when the Enhanced User Interface is enabled in the Settings tab from the Themes page.
A fix will be available in the next version of Advanced Installer, thank you for bringing it to our attention.
visualsi
I may be way off here, trying to interpret the machine generated code, but I am looking what is generated when I select "Windows Server 2012 R2" and I see a test for:
((VersionNT64 = 603) AND ((ServicePackLevel >= 1) OR (MsiNTProductType <> 1))
I believe that 603 does correspond to 2012R2, and the MsiNTProductType not 1 means that it is a server, I think the other part might be testing for a service pack? I don't think a Service Pack has been released.
Rob
Indeed the VersionNT = 603 is for Windows Server 2012 R2 and for Windows 8.1. The installer sets the VersionNT property to the version number for the operating system, undefined if the operating system is not Windows NT, Windows 2000, Windows XP, Windows Vista, Windows Server 2008, or Windows 7. The value is an integer: MajorVersion * 100 + MinorVersion.
Here's the MsiNTProductType property article which explains what meaning have the property's values.
visualsi
Yes, that is where I got that information. I don't need the information - I need a version of your software that works. We do NOT support Windows 2012, but we want to support Windows 2012 R2 (they fixed something in R2 that makes it usuable for us).
If you have the boxes checked like that, it will not install on Windows 2012 R2. We get told that the version is not supported on this version of Windows Server.
I've tried to send in a support request, but your domain refuses email from our domain (visualsi.com) and has since we bought your product. We are not on any public blacklists and we license your product. You can send us email, but we can't send you email.
Oh - it has not been fixed as of version 10.9.1.
Rob Hutchison
Hello Rob,
This fix will be available in the next version of Advanced Installer which should be released soon.
If there is anything else I can help with, please let me know.
First of all I apologize for my previos misleading reply. I've checked againg on our bug system and the fix for this issue has been already included in the 10.9.1 version of Advanced Installer released on February 10th, 2014.
