SteveCk
v10.9 - Can't convert exe to msi!
I downloaded a trial verison of Advanced Installer v10.9. I'm trying to convert an executable (.exe) to (.msi) The executable (.exe) has silent installation switches. However I can't find a way to make it work in Advanced Installer.
For example, I downloaded Firefox latest version (.exe). I can install Firefox (.exe) silently with "-ms" switch in command prompt. I would like to create a (.msi) with silent installation of Firefox. Is it possible to do with Advanced Installer?
If yes, can you let me know how can I achieve this? Frankly speaking, the Docs are confusing!
Thanks.
Re: v10.9 - Can't convert exe to msi!
In order to achieve what you want you should simply follow our "Convert EXE(s) to MSI" article steps.
SteveCk
Thanks for your prompt reply.
I indeed followed those steps mentioned in the article. When I try to run the .msi after build, it still showing regular Firefox installation wizard. Can you let me know where do I need to insert silent installation switch "-ms" in those steps? I'm struggling to make it work particularly on step 4.1 and 5.
Thanks!
SteveCk
"-ms" is the silent installation switch for Firefox executable (.exe)
Any suggestions? Attached screenshots.
Screenshot 1
Screenshot 1
Screenshot 2
Screenshot 2
Please note that if you set the command line "-ms" in the field "Basic UI" it means that your Firefox installer will be launched with this command line only if the main installer is running with basic UI, as our docs explain it. If you run your main installer (built by Advanced Installer) with full UI then you should set the command "-ms" in the field "Full UI".
If you want your MSI built by Advanced Installer to run with basic UI by default please go to Install Parameters page and enable the option "Limit to basic user interface".
