KOgletree
New Website
I have followed the How To at: http://www.advancedinstaller.com/user-g ... e-iis.html
I the user doing the install selects an exiting site the current bindings do not need to be modified. However if they type in a new site to be created, there does not seem to be logic to have the user enter the required bindings information. Any website not using default requires some form of bindings information. If I have them edit the info always they could break an existing site if they do not know the exact settings. What is the best practice on this?
Re: New Website
Please note that there is no need for the user to enter the binding information if they create another website. The user just need to write a new name in the combobox from the BrowseIIS dialog. The information which are displayed for existing website are for just informative and can be modified from the Wizard -> Browse Web Sites and Virtual Directories toolbar button from the IIS page, as you can see in the below image:
Browse IIS ServerWizard.jpg (67.9 KiB) Viewed 1884 times
So, if you don't want to display detailed information about each IIS entity you can Uncheck the related option.
Please let us know if you have other questions.
