bills
Text being cut-off in installer dialog
When using version 10.9 to create a .NET application installer, I am having a problem with the second line in the header of the install dialogs being cut-off.
Thanks.
Bill
Re: Text being cut-off in installer dialog
Hello Bill and welcome to Advanced Installer,
Please keep in mind this is our default behavior. This happens because the "Description" static text control, which resides on "FolderDlg" dialog, cannot display entirely its text if the product name is too long. By default, the "Description" control will display the following text:
This is the folder where [ProductName] will be installed.
So, if the ProductName property is set to a long string, then the above text will get beyond the "Description" control sizes. Therefore, in order to achieve what you want you could set a shorter product name (in "Product Name" field from "Product Details" page) or you can use our "Dialog Editor" feature to edit the "Description" static text control which resides on "FolderDlg" dialog. Please keep in mind that our "Dialog Editor" feature is available only in "Enterprise" or higher project type. You can upgrade your project type from "Home -> Options -> Project Type tab".
bills
Hi Daniel,
Well I created the same install using 10.8 and the long text field had ellipses (...) so it seems from 10.8 to 10.9 you attempted to remedy this situation by turning word-wrap on for the text field. It looks like you need to add just a couple of pixels to the height of the textbox. Perhaps use the same dimension from the example dialog in the production dialog?
Bill
bills
Also, I set the project type to Enterprise in 10.9 build 54791 and using the dialog editor changed the 'Description' field. I moved it up a couple of pixels and made it a couple of pixels wider. I Made sure 'No Wrap' was false and ran the project. I now had the ellipses for the field (...). I went back to the editor and toggled the 'No Wrap' field and had the ellipses displayed in the editor. Again ran the project and still had the ellipses. It appears the 'No Wrap' field is being ignored on the edited dialog.
Bill
Hello Bill,
I'm afraid this behavior is caused by a Windows Installer limitation. However, in order to achieve what you want you can enable our "Enhanced User Interface" feature.
whgibbo
We are also seeing the same for the default theme.. Any way to get around this ?
In order to avoid this behavior you should enable our "Enhanced User Interface" feature and, then set the "No Wrap" attribute to "False" for the related control from "Dialogs" page.
Also, as another solution, you could just resize the related control so that all its containing text could be displayed.
