bills
Error creating AI 10.9 project in VS2010
When I try to create an Advanced Installer project in Visual Studio 2010 I get the following dialog:
A folder and sub-folder is created along with a sln, aiproj, and aip files but they can not be loaded.
Thanks.
Bill
Re: Error creating AI 10.9 project in VS2010
Hello Bill,
I'm not sure why this happens. I've tested the scenario, but I cannot replicate the behavior. Can you replicate the behavior on a clean machine? Also, can you give us more details about the scenario when this error appears? It would be useful if you could isolate a step by step test case scenario which always replicates the behavior.
bills
Hi Daniel,
Installed Advanced Installer 10.9 on a second system running Windows 7 Ultimate with all updates installed. Visual Studio 2010 Premium using Team Foundation server for source control. Same error.
I should add that on the same systems with Visual Studio Professional 2013 installed, I have no problem generating an Advanced Installer project in VS2013.
Thanks.
Bill
Hello Bill,
Can you try to iterate for us a step by step test case which replicates the above error. For example, create a new VS solution, add a new/existing Advanced Installer setup project to the solution, etc. Also, can you tell us if you have more Advanced Installer versions installed side by side on the problematic machines?
You can try to execute the following command as Administrator to reinitialize the Visual Studio 2010 extensions:
"C:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\IDE\devenv.exe" /setup
and see if this fixes the problem.
