TheMen
picture when you hover
Hello!
Please help make this functionality:
that the choice of installation components - field is displayed with the picture. This kind of description of the function. Following the example screenshots.
Big Thx!
Re: picture when you hover
In order to achieve what you want you can implement the desired implementation in an HTML file and add it on an HTML Host Control from your dialogs.
TheMen
Daniel wrote:Hello and welcome to Advanced Installer forums,
Thank you very much for your reply.
Please tell me. Similar functions I need to create HTML in a separate program? Or it is done with the help of a new project in Adv. Installer ?
We don't have support to create HTML files using Advanced Installer.
Return to “Feature Requests”
