R.Mueller
Setup produces IIS Error 4020 on Customer System
I have seen a couple of forum entries related to this issue, most of them are older. Currently a customer is reporting exactly the same issue while installing our product on a Windows Server 2003 SP2 server. He tries to install a feature, which contains some IIS components. The component uses a "Windows Feature Configuration" task, which basically adds IIS 6 Metabase compatibility, but this step should not be executed on this OS (see screenshot).
Do you have a glue, why this happens? (MSI Log is attached in zip)
Roland
error message.zip
(185.87 KiB) Downloaded 428 times
Re: Setup produces IIS Error 4020 on Customer System
Hi Roland,
From the log file, it seems that the issue is on the OnIIsConfig custom action.
In order to get more details about what happens can you download the following debug DLL, replace the original one from the install folder of Advanced Installer 10.9.1 (e.g. C:\Program Files (x86)\Caphyon\Advanced Installer 10.9.1\custact\x86) on your machine and rebuild the package?
Just replace the original iis.dll from the install folder of Advanced Installer with this one, then restart the application and rebuild the package. This DLL should create a debug log (at install time) on the root of the OS partition (e.g. C:\AI_IIS.log), which can give us more details about the problem. So, can you send us the AI_IIS.log file, to support at advancedinstaller dot com, after you will build and test your installation package using the debug iis.dll?
R.Mueller
Hi Dan,
we tried to reproduce the issue inhouse, but without success. The customer refused to use a test version of the setup on his productive server and used a different server with a newer OS instead. This seems to work now.
I am sorry.
Roland
No problem Roland.
I'm glad you got this working. If you have other questions, please let us know.
R.Mueller
Hi Dan,
the customer suddenly wants more details here and a solution. Could you send me a debug iis.dll for AI 11.1?
After receiving the debug results, I will forward it to you.
Roland
Hi Roland,
In order to get more details about what happens can you download the following debug DLL, replace the original one from the install folder of Advanced Installer 11.1 (e.g. C:\Program Files (x86)\Caphyon\Advanced Installer 11.1\custact\x86) on your machine and rebuild the package?
