luluhuhu
Registry removal failed
On uninstall, changed registry folder is not removed even if I used the uninstall cleanup. if no change to that registry folder then it will be removed even without the uninstall cleanup which is expected behaviour.
To reproduce it, I just install the application and implement an action to change the content of the registry key folder (add subkeys and values). Then uninstall, check registry it is not removed.
setting page
setting page
setting page
BeforeRegistryChange
AfterRegistryChange
AfterRegistryChange
AfterRegistryChange
Re: Registry removal failed
I've tested your scenario using the latest version (10.9.1) of Advanced Installer, but I cannot replicate the behavior. Can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
luluhuhu
aip file and logs are sent. please keep me informed.
Regards
Xiao
Freak
Right Click on the registry key to open Edit registry Key Dialog on the Registry Tab(Open By Default) You Get the Check Boxes to Create or delete it On Install or Uninstall respectively
