varmatev
advanced installer pop-up at every login
I am getting Advanced Installer pop-up at every Windows login with a message "The system cannot find the file specified" and OK button.
Other users do not get the popup when login to the same computer running Windows 7 64bit.
I searched the Windows registry, found and deleted Advanced Installer related registry keys, but I still get the popup.
I also see a file named GUI_MVX253723264.exe in C:\ProgramData\Caphyon\Advanced Installer\{8B51B9AB-4C9B-41DE-8339-5D1398BCD75F} folder.
How can I get rid of this annoying popup?
Thank you!
varmatev
Re: advanced installer pop-up at every login
There was a scheduled task to run at the user logon.
The popup disappeared after that task was removed.
I am not sure why Advanced Installer created or needed that task.
I'm not so sure why this happened. The related scheduled task could be created by a setup package built with Advanced Installer which need to resume after a system restart triggered by a pre-install prerequisite installation. However, it would be useful if you could isolate the behavior in a buildable sample or send us a detailed step by step test case scenario which leads to this behavior so we can test and investigate this.
