MLandgraf
Repackage does capture Link to the wrong folder
Dear All,
I have captured a 64Bit install with the repackager (10.9.1).
Installing the AI packaged installation shows broken links of the shortcuts for application start from the desktop.
The installation path is [ProgramFiles 64Folder][Manufacturer]...
In the origial install the shortcuts point to [ProgramFiles 64Folder][Manufacturer]...
The AI shortcuts now use [ProgramFilesFolder]IronCAD... which resolves to "program files (x86)\IronCAD... instead of "program files"
Anything I should set up differently?
Kind regards,
Mathias
Captured Path
Captured Path
shortcut capture to wrong path 2.png (140.14 KiB) Viewed 2832 times
shortcut section
shortcut section
shortcut capture to wrong path 1.png (186.76 KiB) Viewed 2832 times
Re: Repackage does capture Link to the wrong folder
Hello Mathias,
First of all I apologize for my delayed answer.
Indeed, this seems to be an Advanced Installer issue. A fix will be available in our next version of Advanced Installer, thank you for bringing this to our attention. We will let you know when the fix will be available.
Hello Mathias,
This was fixed in version 11.0 of Advanced Installer released on March 13th, 2014.
