yogesh12
Uninstall Error: Using Control Panel, Add Remove Programs
Hello All:
While Uninstalling the application Using Control Panel: "Add Remove Programs" we are getting an error (Refer attachment "Uninstall Error.JPG")
Uninstall Error.JPG (17.11 KiB) Viewed 5857 times
Note: If we remove the application from the created "Uninstall" shortcut (for our application) on "All Program" the uninstall operation is success.
Attached: .AIP file for reference.
SPprotectHomeEdition.zip
(25.56 KiB) Downloaded 698 times
Attached: "HostNmAdminUserNmPWD_1" for reference:
HostNmAdminUserNmPWD_1.zip
(1.88 KiB) Downloaded 452 times
Can someone verify that there no issues in the .aip file and if any can you disclose them and let us know the resolution to fix them.
Thank You,
Yogesh
Re: Uninstall Error: Using Control Panel, Add Remove Program
Hello Yogesh,
In order to have a better view about this, can you please also attach a verbose log of the uninstall process?
yogesh12
Hello Dan:
Attached: The uninstall log
Uninstall.log
(460.14 KiB) Downloaded 704 times
Yogesh
Hi Yogesh,
From the log file I cannot see any error or any warning messages. So, it looks like your product is successfully uninstalled. Did you get any error when you created the uninstall log file?
yogesh12
Hello Dan:
The log is created using the Remove (button) option during the maintenance mode.
The installation work without any issue if we uninstall the application using the "Remove" button (during maintenance mode) or using the created Uninstall shortcut present under "All Programs".
If we try to uninstall from the "Add Remove Programs"/"Uninstall a Program" present under "Control Panel" then the error message is displayed. And this error is displayed as soon as you click on the program "Uninstall" option
Please suggest
Yogesh
