davidesharpe
Cant import a vs2010 setup project
I am using Advanced Installer 9.8 , but attempting to import an existing vs2010 setup project gives an "The application ran itno a problem that it couldnt handle" error, see attached screen shot.
Any way to find out what the issue is ? or is it a known issue ? And what's the fix ?
Re: Cant import a vs2010 setup project
We are not aware of such an issue.
Can you please try to use the latest version of Advanced Installer(version 10.9.1) and see if the behavior persist? If the 10.9.1 version of Advanced Installer is not covered by your maintenance plan, then you can test it in trial.
Here is the Advanced Installer Download page.
