lidds
Patch installer does not skin correctly...
I have built an installer using your Graphite Metal Chrome Red theme. This theme works perfectly fine when carrying out a full install, however when I build a patch it does not skin the installer correctly. The window uses the standard Windows style and also all controls on the form seem to not use the transparent property and as a result shows a grey box around the control extent, please see attached image.
I have enabled the bootstrapper option on the patch, but this does not seem to fix the problem.
Simon
lidds
Re: Patch installer does not skin correctly...
Another image
Hello Simon,
This is happening because the patch does not support the Enhanced User Interface feature.
Please note that using any other theme than the Classic one require the Enhanced User Interface feature which is handled by our bootstrapper and require an .EXE package type. Unfortunately, a patch cannot be created between the .EXEs, so the theme is not displayed correctly because the MSI handles it.
lidds
Dan,
Thanks for getting back to me. In this case is there a way that I can remove the interface completely and just get the patch to show a reduced standard Windows status message form to install the patch?
Simon
Hello Simon,
In order to launch your patch installation with Basic User Interface you can add the /qb statement in the Command line field from the Patch Media Bootstrapper Tab of a Patch project.
Unfortunately, due to a recent bug in Advanced Installer, the msiexec commands line are ignored. A fix will be available in a future version of Advanced Installer. Thank you for bringing it to our attention.
As a workaround, you can skip several dialogs from the Patch – Install Sequence Dialogs. (e.g. PatchWelcomeDlg and ProgressDlg).
In order to achieve that, you can go in the InstallUISequence table from the Table Editor page of the upgraded project file and add in the Condition field for the PatchWelcomeDlg action a false condition(e.g. 1 = 2) and for ProgressDlg action you can add something like NOT AI_PATCH.
The issue related to the msiexec command line statements which were ignored in a "Patch" project was fixed in version 11.1 of Advanced Installer released on April 28th, 2014.
