rm.matheus
Problem to add, Advanced Installer
Good afternoon, my name is Matheus, I'm from Brazil, I'm with a problem, When I will add, the Advanced Installer in my project using Visual Studio 2010, him returns a problem for me, the error is below this coment, I followed you the tutorial and made the download of trial version.
Thanks all, I wait for guys.
This is error
This is error
Re: Problem to add, Advanced Installer
I'm not sure why you encountered this behavior. Every time you try to Create an installer from Visual Studio get that error?
You should take a look on the “Windows event viewer” log where you might see why is this happening. Also, can you please try to test on another clean machine and see if the behavior still persist?
rm.matheus
Good Morning, Dam,I repeated the previous procedure. I installed the VS in a Virtual Machine Windows 7, the VS returns the same error, I saw the log, didn't returns nothing, more some idea ?
Thanks for help. I wait for guy
Hi Matheus,
I'm afraid I cannot replicate the error that you get.
Can you please send us the solution and project files (without the sources) to support at advancedinstaller dot com, so we can analyze deeper your scenario?
Also, can you please give us a detailed test case so we can investigate this? By the way, what version of Visual Studio are you using?
rm.matheus
Hi Dam, I'm using VS 2010 Ultimate, My project is simple, just start
Visual Studio -> New Project -> (Project name = Test, Location = C:\Users\matheus.moreira\Desktop\) -> I press button OK, I don't add any code,
After this,
I click, File -> New Project -> Advanced Installer Project -> (Name = Default(AI Setup Project1), Location = C:\Users\matheus.moreira\Desktop\, Solution = Add to Solution), then I click OK, VS returns the error.
Hi Matheus,
I've tested your scenario but I cannot replicate it.
Tested Environment: Win 7 Professional - 64bit with Visual Studio 2010 Ultimate Vs 10.0.30319.1.
So, can you please tell us on what Operating System do you get that error? Also, what project type do you create in Visual Studio?
Also, can you please check in Visual Studio if the Advanced Installer Path points to the installation folder of Advanced Installer (the default one is C:\Program Files (x86)\Caphyon\Advanced Installer 10.9.1\). This can be seen in the Tools -> Options -> Advanced Installer Extension.
