slawomir.zurek
Translation edit problem
I cannot change translation for "Control.Text.MaintenanceTypeDlg#Title". I can edit it in "Default strings" window, but after saving dictionaries and restarting Advanced Installer there is original value back. I investigated "ui_pl.ail" dictionary (stored in "program data..." path) and there is correct (entered by me) value.
This happens when I edit Polish translation - changing English one works ok.
I changed succesfully few other translations - only this one is "refractory" ;-)
Best regards
Slawek
Re: Translation edit problem
Hello Slawek,
I've tested your scenario using the latest version of Advanced Installer and it worked as expected.
Can you please try to isolate the described behavior in a sample and then attach it on the forum's thread so we can investigate it?
slawomir.zurek
I think I found problem.
I locate problematic line in .aip project:
<ROW Dialog_="MaintenanceTypeDlg" Control="SubTitle" Type="Text" X="17" Y="105" Width="312" Height="20" Attributes="196611" Text="Zmień, Napraw lub Usuń instalację" TextStyle="[SubTitleStyle]" Order="1500" TextLocId="Control.Text.MaintenanceTypeDlg#Title" MsiKey="MaintenanceTypeDlg#SubTitle"/>
It looks like TEXT property does not change in current (existing) project after modifying translation. New (translated) value is applied when I create new setup project.
Slawek
PS: main setup project parameters:
- proffesional project
- one single exe
- white surface theme
- two languages (polish, english)
