eramos
Update application Delphi XE4
Hello i create install package with updater
How do I integrate the advanced updater with my application?
in this page http://www.advancedinstaller.com/user-g ... dater.html only indicate how can i do it in C#, Java and Vb.Net
but not in "DELPHIXe4"
How can i do it????? o advanced installer didn´t support it??
Thank you
Application .EXE in DelphiXE4.jpg (221.06 KiB) Viewed 3550 times
Re: Update application Delphi XE4
Please note that the Advanced Updater can be easily integrated with your application since you only have to launch it using an adequate command line option.
You can use the Integrate Updater In Application article which you can follow in order to get a starting point for your scenario.
Unfortunately, we don't have any samples regarding the Integrate Updater in Delphi Application.
If there is anything else I can help with, please let me know.
eramos
Hello thank you for your answer but sincerely i dont understand very well
I read " Integrate Updater In Application " but in finals lines
tell : This corresponds to the "OnTimer" function from the sample code.
I need to create a "onTimer function"???? Where?
I dont need to creat a shourt file for mi .exe??
Thank you
