rmusick
Repackaging SQL Server R2 Express
Can someone tell me what is gong on here? I am trying to do a MSI from EXE. I am running SQL Server r2 express as a native install and it is locking up. When I kick off the MSI, the install looks and runs normally. It gets to a certain point on the Setup screen and just sits (See attachment.)
Here is the command line I am using:
SQLEXPR_x86_ENU.exe /QS /ACTION=INSTALL /FEATURES=SQLEngine /INSTANCENAME=QSRNVivo10 /SQLCOLLATION=Latin1_General_BIN /SQLSVCSTARTUPTYPE=Automatic /SQLSVCACCOUNT="NT AUTHORITY\SYSTEM" /SQLSYSADMINACCOUNTS="BUILTIN\ADMINISTRATORS" /IAcceptSQLServerLicenseTerms="True"
If I run the script outside of the MSI package, it runs just fine.
Re: Repackaging SQL Server R2 Express
This may happen due to a Windows Installer limitation when installing SQL Server 2008 R2 as a feature-based prerequisite within your installation package.
So, the recommended way is to add it as a Pre-Install prerequisite.
However, if you still want to add the SQL Server 2008 as a feature-based prerequisite you can try to implement the workaround debated in our "Installing SQL 2012 Based On A Feature" thread.
