shetty_rohan
DialogBitmap does not appear in the Setup
I have attached a sample setup file in which I have added a "dialog bitmap". Bitmap does not appear when I run the installer. Can you please help me with this?
Steps to reproduce
1) Extract the attached zip into a folder
2) Open the .aip file
3) Build the aip
4) Run the setup.
You could see the left hand side of the setupscreens do not have any bitmap
Note: It works with some other bitmaps.
Rohan
tempinstall1.zip
(13.42 KiB) Downloaded 412 times
Re: DialogBitmap does not appear in the Setup
Hi Rohan,
I built the AIP you sent, ran the package and it worked well to me, as you can see in the image below. Can you test it on a clean machine and see if the problem persists?
Bitmap Test.png (25.92 KiB) Viewed 4477 times
shetty_rohan
Thanks Eusebiu. I guess this happens only in XP(have you tried this in windows XP)
I had tried this multiple times, it did not work.
In the mean time, I tried to edit the bitmap(i.e kept the white area width same as the default dialog bitmap which comes with the AdvancedInstaller), then it started working fine.
Anyways, you could consider this problem as resolved.
You're welcome Rohan. I'm glad you got this working.
Indeed, I tested now and reproduced the issue on Windows XP, but it seems that there is a problem with the image. I opened it with "Windows Picture and Fax Viewer", saved it in the same folder and using the saved image it worked well on Windows XP, too.
shetty_rohan
Thanks Eusebiu.
