onlyicemac
System especification File not found.
Hi!
This tool is amazing, I´m in trial mode and find great, however I had create and professional setup,
but when I tried to install in a "normal" machine (no .net framework, just 4.5) the setup show me something like "system cannot find the file specified", using verbose mode to identify the problem, the log was:
=== Verbose logging started: 24/03/2014 09:56:03 Build type: SHIP UNICODE 5.00.7600.00 Calling process: C:\[MySetup].exe ===
MSI (c) (30:FC) [09:56:03:160]: Note: 1: 2203 2: C:\[MySetup].msi 3: -2147287038
MSI (c) (30:FC) [09:56:03:160]: MsiOpenPackageEx is returning 2.
=== Verbose logging stopped: 24/03/2014 09:56:03 ===
Any information about it?
Thanks in advance!
Re: System especification File not found.
In order to have a better view about this, can you please send us the .AIP (project file) and the full verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
onlyicemac
Thankyou for the answer, however I had found the problem. It was a miss configuration. After I changed the problem was resolve.
Thank you again!
You're welcome,
nedumaran
Hi, We're experiencing the exact same problem. Could you please help up understand what that mis-configuration is so we can try that with our project as well?
Thanks.
Can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
