tinaraj
Unable to run Advinst.msi
I have downloaded the installer from wwww.advancedinstaller.com. Version 11.0
My OS is Windows 7 (64 bit)
When I tryi to run , I get the error as shown attached. please let me know what is to be done
Tina
Error during running advinst.msi setup
Re: Unable to run Advinst.msi
Hello Tina and welcome to Advanced Installer forums,
This problem may occur if the Windows Installer package (.msi) file is damaged.
So, can you please check the integrity of the downloaded file? See attached print screen for reference.
If it is not, please proceed with another download.
tinaraj
Hi Dan,
Thank you for the reply. I checked and it shows the same size as you had mentioned. Is it something to do with 64bit as my system is 64bit?
I have added the same as attachment
Tina
Hi Tina,
Advanced Installer can be installed on the 32 bit Operating System and on 64 bit Operating System with no problem.
Have you tried to delete the old downloaded file and then begin a new download?
If this didn't help you either, can you please try to Start the Windows Installer service and see if the behavior still persist?
The Windows Installer service adds, modifies, and removes any applications that are provided as an .msi package. If this service is disabled any services that depend on it will fail to start.
To verify that the Windows Installer service is running and to enable it if it is not, follow the steps below:
  • 1. Press the Windows key + R, type Services.msc into the field and press Enter.
    2. Locate the Windows Installer service in the Services window, right-click it and select Properties.
    3. Select Automatic from the Startup type drop-down and click Start.
    4. Click OK and try the installation again.
Try to run Advanced Installer and see if the behavior still persist.
If that didn't help you either, can you please try to install Advanced Installer on another machine (even virtual one) and see if the behavior still persist? Also, do you have any anti-virus which may block the installation process?
