we have developed a java application which uses OpenGL to render 3D content in fullscreen mode.
We use swing JFrame which contains a opengl panel for drawing.
Additional we use Gestureworks http://gestureworks.com/ to receive multitouch events and gestures.
Gestureworks needs to know the window (JFRame) handle to receive touch events.
Everything works pretty well when i start the deployed application from the command line like:
javaw -jar [params] Start.jar
When i start the application with the exe wrapper the window and thus the app did not receive any touch events.
Is there something special window or context the exe wrapper uses to start the app.
I tried to use gui or cmdline for the application type.
Folowing you can find the ini file the exe wrapper uses:
[Application]
Application Type=gui
Override WorkingDir=yes
[Class Path]
Class Path=...
[Java Runtime Environment]
Main Class=...
Maximum Version=any
Minimum Version=1.7
Virtual Machine Parameters=-Xms500M -Xmx550M -Xss10M -Dlog4j.configurationFile=logging.xml -Djogamp.gluegen.UseTempJarCache=false -Dsun.java2d.noddraw=true
[Product Information]
Upgrade Code={...}
Product Name=...
Product Code={...}
Do anyone has any ideas what could be the problem here?
