mbilet
UI issue when screen size is set to 125% or 150%
I have an UI layout issue when I change screen size to 125% or 150% on Windows 7 in Control Panel -> Appearance and Personalization -> Display.
Also text is going beyond the text field in 125%/150% mode.
Could you help me to fix this issue, maybe I should change some dialog or text field property.
Environment:
- Win 7;
- AI 10.1
Mykola
Re: UI issue when screen size is set to 125% or 150%
Hello Mykola,
The problem of the "Prerequisites" dialog is already on our TODO list and it will be fixed in a future version of Advanced Installer. I'm afraid that we don't have any workaround for this problem.
To fix the second problem, of the "WelcomeDlg" dialog, you can go in the Dialogs page, select the "WelcomeDlg" dialog, then select the "L'Assistant de Configuration..." text and in the "Properties" pane modify the value of the "Y" field to "110" for example. Also select the "Bienvenue dans..." text and modify the value of the "Height" field to "80" for example.
Please keep in mind that our "Dialogs Editor" feature is available only in an " Enterprise" or higher project type.
mbilet
Thank you Eusebiu
Could you tell me which "AI" version will include the fix for this issue and when it will be released?
- Mykola
Hello Mykola,
I'll keep you posted on this thread once the dev team gets a chance to investigate and fix.
The fix will most probably be included in the next release after the undergoing one.
This was fixed in version 11.1 of Advanced Installer released on April 28th, 2014.
