shetty_rohan
Windows firewall displays the "Product Description"
In the aip file, I have the following
Product name : DesktopControl
Product description: DesktopControl allows you to manage your telephony features, and to communicate over the TELES telephony system at any time and from any place.
One of our customer reported a problem(saying "Product Description" is displayed instead of "Product Name".I guess "windows firewall" displays the "Product Description" instead of the "Product name"
Is it possible to fix this issue? Or is it a windows limitation??
Rohan
Re: Windows firewall displays the "Product Description"
Hi Rohan,
The description which is displayed in the the UAC box can be set in the Description field from the Digital Signature page.
So, can you please make sure that you set the right description? e.g.:
[|ProductName]
This Description field contains the signed content's description. It will be showed by the Windows UAC after you click the "Install" button.
shetty_rohan
Thanks Dan. I had left these "digital signature properties" empty. Now, I have updated these, so it should work.
You're welcome Rohan,
