qakmak
Why the msi file will not response when register ax file?
Hi, I have a install package, I'm trying to install some file. but there is a ax file always let the install thread no any response.
I check the log, there is display:
SelfRegModules: File: file.ax, Folder: C:\WINDOWS\system32\
and there is no any response.but I still can use regsvr32 command register it manually.
So is that a bug, how can I fixed it ?
Can you help me check it please? thanks.
example.rar
(689.5 KiB) Downloaded 254 times
qakmak
Re: Why the msi file will not response when register ax file
Hi, Is there any one can download my example and check? thanks.
qakmak
Is that a BUG from Advanced Installer 10.5?
I'm not sure why this happens. However, since you are able to manually register the above file using regsvr32 tool, then you can use a custom action which will call the regsvr32 to register your file. Here are the steps to proceed:
- go to "Custom Actions" page and add a "Launch File" custom action with sequence, scheduled after "Install Execution Stage -> Add Resources" actions group, like this:
  • File To Launch: regsvr32.exe
    Command Line: [#file.ax]
    Working Directory: [SystemFolder]
    Run As Administrator: checked
    Execution Time: Deferred
    Execution Stage Condition: Install
- build and run your project
Let us know if this helped.
qakmak
Daniel wrote:Hello,
Thank you for reply. But I still hope you can check it . I already give you the aip file with ax file. Why don't you just download and debug it ?
Then maybe you'll find the problem source and If that's your application problem you also can fixed the BUG. thanks.
qakmak
Daniel wrote:Hello,
Hi Daniel,I'm trying use the way you told me test it . but when I run it on XP, it will always display a dialog:
but If I disable: run as administrator it will fine. then how can set it don't display on xp but still run as administrator?
select user.png (13.67 KiB) Viewed 5139 times
I've tested your scenario and indeed I was able to replicate the behavior. However, this could be caused by a Windows Installer limitation. Our "Self register native library" registration option uses Windows Installer "SelfRegModules" action to register files. Please keep in mind that the self registration method have many drawbacks and it is against Microsoft guidelines. Therefore the recommended method to register a file is by using the "Extract registration info from native library" option.
I'm afraid this is the normal behavior on Windows XP OSs when enabling our "Run as administrator" option and you cannot suppress this.
