kog
Bundle installer
Hi all,
I would like to migrate our old NSIS made bundle installer to Advanced Installer and would like if anyone could point me in a direction that allow me to excel quickly.
The bundle installer should offer a selection of install packages (3rd party and proprietary software) and based on selection install one after another - so to speak, this bundle installer should only be a "wrapper" for already made installers. How do I go about not to lose precious time? :?:
Thank you in advance for any useful tips. ;)
Gorazd
Re: Bundle installer
Hi Gorazd and welcome to Advanced Installer forums.
In order to achieve what you want you can use the "Prerequisites" feature support. For more details you take a look and follow the steps from the "Add Prerequisite" tutorial.
kog
The current bundle installer made with NSIS does this:
- standard license info, welcome dlg,...
- dialog with check box tree where user can select which packages will be installed on the system
- sequential installation of the selected packages (abort or at least warn if any of the installers fail)
- write a complete installation log
The installation packages are divided in two groups:
- 3rd pary software (Adobe Reader, JRE, or similar...)
- proprietary software (tool 1, tool 2, tool 3)
Some of the proprietary packages are mandatory everything else is optional.
ad: I am currently trying out the suggested Prerequisites approach but am struggling while it gives no property condition options (or am I missing something?).
Hi Gorazd,
You can choose which dialogs to be displayed from the Dialogs page as described in the Set dialogs to guide the user during install tutorial.
To achieve this you can add the "ConfigureDlg" dialog.
This is the default behavior, the selected packages will be sequentially installed.
The "Enable verbose logging" option can be found in the Install Parameters and it writes a complete installation log.
To achieve this you can use the "Continue with main installation even if the prerequisite is not installed" option that is available in the "Properties" tab of a prerequisite.
All the conditions of a prerequisite can be set in the "Install Conditions" tab. If you want to use a property as a condition, you can add those prerequisites in the "Feature-based" folder from the Prerequisites page and then set the conditions in the Organization page using the "Add Install-time Conditions" option.
kog
Thank you for a promptly reply. I hope the suggested steps will bring me up to speed with creating this bundle installer. I have to commend that Advanced Installer is a great tool ;)
You're welcome Gorazd. Glad to help.
I'm glad you like Advanced Installer. Just let us know anytime you need help.
kog
Is there a way of defining prerequisite as a mandatory :?:
I've used the PrerequisitesDlg :idea: instead of suggested ConfigureDlg and everything works great except the lack of restricting the user from not installing the mandatory packages. Is there a way of achieving this?
NEVERMIND: figured out in the meantime :) :roll:
