chrisyroid
Folder search defined by a property
I'm having trouble searching for a directory defined by a property.
The program I'm working with can be installed anywhere and creates a registry value based on it's location so I want the installer to look for where it's located using the registry.
I've been trying to find it by first creating a new search term from the registry. That seems to be working.
Then I create a new search and look for a folder referencing the previous property. I get "1: C:\" as my search result.
I've included an example as an attachment.
test_search_1.aip
(10.99 KiB) Downloaded 218 times
Re: Folder search defined by a property
Please keep in mind that the searches created in the Search page are executed randomly by Windows Installer, so I'm afraid that you cannot create one search dependent on another. You can take a look on the Search order: Searches creation order is not maintened thread which debates a similar problem.
