dms
Failed to start Visual studio
Hi
AI V 11.0
I'm getting the following error trying to import a visual studio project into AI to ready it for deployment as illustrated in the attached imaged. Has anyone else encountered this with the latest version of AI.
Dom
Edit:
Have tried a full uninstall and reinstall of AI. Still seeing the same error whether I start with a Visual studio Application wizard, or simply try and import a visual studio project in a newly created project.
Edit 2:
Have tried this on a different machine, this time it works as expected. So whether this is a specific AI or Visual studio corruption on this one machine I'm not sure, but it does appear to be machine specific.
Re: Failed to start Visual studio
Hello Dom,
We are not aware of such an issue.
As far as I can see, it seems that something is damaged on the related machine since it works as expected on others.
dms
Hi
I'm sorry to come back to this but it's getting to be very frustrating.
I have completely rebuilt my main development machine, fresh install of AI (11.1) and fresh install of Visual studio 2013 premium (update 2). I'm still getting this error for the majority of occasions I try to import a visual studio solution. The rest of the time is succeeds in starting visual studion but then hangs when it comes to closing visual studio.
Any ideas?
Dom
Hello Dom,
This issue is currently under investigation. As soon as I have a conclusive answer I'll get back to you.
Hello Dom,
I'm not sure why you encountered this behavior. I've tested your scenario but I cannot reproduce it.
Tested on a fresh Windows 8.1 64-bit machine with Microsoft Visual Studio Premium 2013 Version 12.0.30501.00 Update 2.
So, can you please send us the solution and project files (without the sources) or a sample project which replicates the described behavior to support at advancedinstaller dot com, so we can analyze deeper your scenario?
