congnt92
open a special file after finish installing application
Hi all.
I want to open a special file after finish installaing my app. I use a check box, if check box was ticked and press finish button, the file will be opened.
For example, If the installation error, the error fatal dialogue display, I remove log check box and replace it by my custom check box. When we check this box and press finish, my custom .txt file will be opened.
Please help me.
Re: open a special file after finish installing application
Please take a look on the Launch file after installation article with related information for hints and guidance.
congnt92
Thanks for your reply, Dan.
But I still have a question. If it is not exit dialogue, such as, Fatal error dialogue, and I want to launch a .txt file when the installation is error.
Example, I don't want to use Log Check Box to open log file, I deleted the log check box in Fatal Error Dialogue then created new check box and use it to launch a .txt file. This .txt file was created by myself, not by msiexec.exe. Can I do it?
In order to achieve that you can add the predefined Launch file custom action without sequence from the Custom Actions page.
Then, in the Dialogs page, you can add this custom action to be executed as a published events on the Finish button from the FatalError dialog. Here's an article with related information for hints and guidance: How do I execute a custom action when a button is pushed?. You can condition the execution of this custom action depending the checkbox control state.
Please let me know if you have other questions.
congnt92
I'm sorry for my limited knowledge. If the special .txt file was put on desktop, what string must be type at "File to launch" feild. It is "%userprofile%\desktop\log.txt" or "#%userprofile%\desktop\log.txt" or what? Thanks :)
Since you are using a reference to an environment variable (e.g. USERPROFILE) you should use something like that:
"[%USERPROFILE]\Desktop\log.txt"
You can take a look on the Windows Installer Formatted Type article which may be useful to you.
congnt92
Thank you very much, Dan. God bless u :)
You're welcome,
