mach1muscle351
Finding Proper Paths
So I would like to start out this is my first project (aside from messing around on it) I am attempting to build an installer for an Arma 3 modifcation. Which will include automatic patching. However, before I do the automatic updating/patching. I need to focus on meeting my requirements for the installer itself.
I want simply dump the modification folder into the proper directory (easy peasy) for the main files itself. However, I would like to include a bunch of feature based items (also this question pertains to the main dump folder). So, the main question is how do I go about telling the folder how to find the root folders for the required mods. In other words how do I make it to automatically find the arma 3 folder?
I am trying to make it so it will automatically find the Arma 3 folder (where it will dump the mods), and also the teamspeak 3 client plugins folder because that is the second file that I will need to input another folder into.
Last question is not so much directed towards the Advanced Installer software itself. How would I go about making this so It is an EXE icon on the desktop that will do its update checks and then go to a launcher page. In other words. I am inquiring about where I should look and what to learn about making a very simple launcher that will join a predefined server?
Re: Finding Proper Paths
To achieve this you can go in the Search page and create a registry search, folder search or file search to find the path you need.
For this scenario you can use the Advanced Installer Updater as described in the Using the Auto Updater tutorial.
