Aravindadx
Install Certificate as Trusted Root
Hii Friends,
I'm a new comer to Advance Installer. However I use the Advanced Installer 10.8 version. Now I need to Know how to install a certificate file to Trusted Root when begin the setup file. I have created certificate files and I have digitally signed my setup file and program file correctly. I think this operation needs custom actions. But I haven't knowledge or idea about custom actions to do this. So if you can help me I'm appreciate it very much and more. (I have attached a picture file about digital certificate.)
Thank You!
Digital Certificate
Digital Certificate
Re: Install Certificate as Trusted Root
Unfortunately, we don't have support for installing certificate files to Trusted Root Certification Authority . However, as you already felt you can try to create your own custom action in order to achieve this. You can take a look on the "How to programmatically install a certificate using C#" and "Create fully fledged C# custom actions" threads which could be useful for you.
Aravindadx
Hello Daniel,
First of all thanks a lot to describe me about this forum. However these tutorials very helpful to me.
Thank You!
You're welcome.
